Joethemechanic
- Hazleton Pa
- Electro-Mechanical Technician. Industrial machinery
First google result
:rotflmao:
[h=1]Three-Phase and Single-Phase Power[/h]  Shop owners discuss running a single-phase motor using two legs of a three-phase power source. May 28, 2006Question
We have a 240 3 phase service. I was wondering if I can run a 240 single phase motor off of 2 legs of the three phase panel? Also, what if the motor is rated at 220 single phase - will using 2 legs of a 240 3 phase feed hurt it?
Forum Responses
(Solid Wood Machining Forum)
From contributor B:
Yes, you can run a 240v single phase motor on two legs of a 240v three phase service. You will actually be running on 208 volts, but that is within range of the motor tolerances.
:rotflmao:
