We just purchased a new industrial machine and I received a preliminary copy of the wiring schematic today.  It shows many conduits run to remote pull boxes and from there split out to devices, mostly solenoids and limit switches.  The conduits all contain both motor and control wiring.  The devices are all to be wired using Belden 8770 shielded cable home-run all the way back to the MCP.  Control is 24VDC, motor wiring is a mix of 240 and 480 VAC, some run via inverters, some via motor starter.
The number of control cables greatly outnumbers the number of motors on this machine. A little quick math tells me that it would have been far less expensive to run the motor leads in shielded cables and use MTW for the control wiring. Is there a reason to do it the way they did? The manufacturer didn't really give me an answer when I asked.
