- Massachusetts
Dennis, I just did what I said above, I found 25 hits across 8 of the documents for your name.
Interesting , I did it and got 20-- I'll try again . Thanks- that was a good idea. :thumbsup:
perhaps there is another person with your last name.
I am only getting hits on panels 2, 4, 5, 6, 7 and 9-- that is 6 panels and you are getting it on 8???
For those intrested the proposals are posted from most of the CMP's on the same site that Don Referenced.
Ballots! Got it, thanks!
If anyone wants a copy that has all the different files merged, shoot me a PM.![]()
Thanks, I read this after searching all 19 pages individually. :roll:
Two of mine that I found say Accepted what does that mean at this point?
Chris,That means that the CMP has accepted you proposal and it will be incorporated into the 2014 NEC, unless they are rejected at the comment stage.
3 of mine were rejected and 2 were accepted in principal.
I am going to submit comments on the 3 that were rejected.
Chris
Chris
After the ROP is published. It is scheduled to go to the printer June 15th, so it should be available online around then or a little before. The closing date for comments is October 17th.When does the comment phase begin?
