- Massachusetts
I know for certain there are inspectors that have no problem with heat guns.
I know that as well, I have also used almost any source of heat you can think of.
Neither of those facts changes my opinion of the code section.
In my opinion if you use a heat gun to form pipe it is a is a tool used to bend pipe.
You have pointed out your opinion, my opinion differs.
Imagine that, a public official enforcing the codes they were hired to. Shameful
My opinion would be the same as yours IF I use the heat gun to FORM the pipe. I am not. When I am done heating, the pipe is still straight. I use my hands for forming the pipe.
Now, if I continue using the heat gun while forming the pipe (which I would never, ever do), I concede that I would be using the heat gun to form the pipe and to be compliant I shall use a device identified for the purpose.
Even with that little nuance thrown in??
Edited to add:
If you think we need an identified device for heating prior to bending, do we also need one for cooling after the bending?
I'm guilty of using a torch to heat PVC for bending. Problem is, you won't be able to tell what I used for the heat source because I'm patient and don't damage the PVC.
In a pinch, I will pool some PVC glue in the dirt and make a campfire. Only problem with that is the smoke can discolor (note I did not say damage) the PVC calling in the question of how it was heated.
Your interpretation of the code seems to be that heating and bending are synonymous, and as I have pointed out, they are not.
Pedro, you're going to have to use the 'search' function if you want to see the rather recent thread on this topic - where I posted pics of my "PVC BBQ."
I have mentioned it before (I think in renostienkes thread) that you don't bend the pipe with the heater, you prepare the pipe for bending with the heater.
I have burned pipe in a hot box before - you can not leave it unattended or this happens. it is just as burned as with something other than hot box.
If NEC intends you to use only heating equipment designed for the purpose then maybe they should word it that way.
But what if you use controlled heat to bend the tubing. In the same way as you use a rosebud to heat the flange of a steel I beam in order to camber it?
I'm sorry but why can't you use a shoe type Bender or hand Bender with the spring item that you can get at supply houses? Aren't hand benders listed as bending emt or ridgid? 3/4 emt 1/2 ridgid I believe is what they state. Is pvc not called ridgid nonmetalic conduit? Or am I just way off base. Btw if inspector said I couldn't use that or heat gun or what have you we would have issues.
