jimingram
- St Paul MN
I am working in a four year old state of the art private school.  I am puzzled that in the exterior recessed luminaires that I'm finding 100 watt metal halide lamps. I needed to pull out the ballast in one of these lumianires and noticed that it was only rated 70 watts. Also, this is not just in one isolated fixture.
I called the local Lightolier rep. to ask how these 100 watt lamps could work on a 70 watt ballast. The rep. called the factory, but that was a futile effort. I've spent the last 25 years on the service truck. I would always match the lamp with the ballast. That's one of the reasons I rarely had a callback. What's especially puzzling is how well these 100 watt lamps work. Typically when I'd find a higher wattage lamp in a lower rated fixture, that lamp was burning dimly. The proper size lamp would burn brighter.
1)How can a 100 watt metal halide lamp work so well with a 70 watt rated metal halide ballast? Multitap ballast 120/277. Ballast operates at 277 volts.
2)Is there any bad consequence for using the higher rated lamp?
