richc516
New member
- plainview, ny
Does anybody have a clear understanding of this rule? We are doing a large project in NYC and have most of the building roughed. The GC is now telling is that some of the boxes in fire rated walls require putty pads. I have seen the code (NFPA maybe?) that describes that a box that is over 16 square inches (which applies, in some cases we used oversized boxes), a 100 square foot area, etc, etc and I have also seen literature from STI, Hilti and 3M on this. What is strange to me is that this has never come up on our projects before, by a building or electrical inspector. Another thing I cannot understand is does this rule apply to the size of the box or the opening in the sheetrock wall. We mostly use single gang adapters. Also, steel boxes have a two hour fire rating, so shouldn't that be sufficient enough and basically be part of the two hour fire rated wall? I might not be doing a great job of describing this, but if anyone can shed some light on the subject, it would be appreciated.
Thanks
Thanks
