Strahan
- Watsontown, PA
We are currently going through an electrical audit at our plant. First we are being told that all our receptacles need a bonding strap from the recep to the box. I always thought the bonding took place when you fastened the recep to the box as long as you remove the plastic pieces.
Next we are being told we need ground wires run to these receps. The conduit runs are all RMC. I thought this was a suitable grounding method? Does it say anything in the new code about compound that needs applied to the threads in order for it to be a suitable ground in wet locations?
Finnally he also told us that tripping our GFCI's will shorten the life of our GFCI's. I might buy this to a point but he said that they are all made to only trip a certain amount of times then they will not reset anymore. What about OSHA'a requirements to test the GFCI's already in place in our facility? Will this essentially kill the GFCI and is this something we can plan on replacing every couple of years?
