As long as clearances are met and the antenna isn't installed in a right of way there shouldn't be a problem. Of course, with that being stated let me tell you true story.
I went on an outage call one afternoon, and immediately rode the line out to find out why the fuse blew. After making sure the line was clear(about 20 minutes), we went and refused the line, restoring power to the neighborhood. Looking further, we found an antenna with burn marks about 4.5 feet apart at the top of the antenna. The lady of the house came outside and wanted to know what happened.(she had came home while we were patrolling the line). We informed her of our concerns and she called around, ultimately finding her husband in the emergency room with holes blown out of the bottom of his feet (small holes). Apparently the husband was installing the antenna too close to the power lines and stuck the antenna into the lines, striking the neutral wire first before hitting the primary line. He lived, actually he came home that day, and he received a visit from our safety director a couple of days later.
The point is, watch what you are doing. Make sure before you start that the antenna will not hit the power line when installing it, or when it falls down in a storm.
As far as RF noise, if there is some, the POCO should be quick to fix this. It is generally caused by arching somewhere on the line, whether it is hardware breaking down, or something as simple as a loose bolt on an insulator.
