Sulphur vs insulation
powerplay
Canada
Electrical Contractor
I've heard that sulphur burners are used in agriculture for various reasons, but that when in contact with moisture it becomes corrosive. Does this not eat away at anything metal...like receptacles?
In PVC conduit, T90 conductors should be fine pulled in? Thanks again!
Burning sulfur can ultimately generate H2S (highly toxic) and, with water from the atmosphere, H2SO4, (a highly corrosive acid.) It corrodes most metals. In small amounts, it does dilute fairly quickly - but "small amounts" is a relative term.
I think sulphur* burns (combines with oxygen) to become SO2.
Combine that with water (H2O) and you have H2SO4
That's sulphuric acid. Which is corrosive for most metals.
But that's dragged of of memory of chemistry lessons from school about five decades ago.
*British English spelling. :)
You're right as to the fundamental H2SO4 process. The H2S is generated as a different process; they are often concurrent but do not necessarily have to be - thanks for the gentle correction.
