Receptacle
Receptacle
  • Fail
    Votes: 3 27.3%
  • Pass
    Votes: 8 72.7%
  • Total voters
    11
  • Poll closed .
resistance
WA
Exterior generator Inlet installed behind-but above (Meaning: If you stand in front of the heat pump, and look directly at it, you will see the inlet about 6 inches above it)-permanent heat pump. Would you fail or pass this install?
I'm not sure what you mean? Could you elaborate?:?
A generator inlet surface mounted to an exterior wall behind a generator, but above (about 6 inches)—meaning able to be easily reached by hand. Note: It's pretty much the same as having (or installing) an AC disconnect.
I would pass it if it was the only choice of location..
A generator inlet surface mounted to an exterior wall behind a generator, but above (about 6 inches)?meaning able to be easily reached by hand. Note: It's pretty much the same as having (or installing) an AC disconnect.
Usually an ac disconnect is off to the side instead of up top though.
