schematic is missing. overheat thermostat is "open" which seems to be the problem with the dryer. I just happened to note the resistor was "open" also. assumed (I know) it was a suppresion acorss the button.
I did a Google search and found that a resistor is sometimes used to keep the timer motor going.
Here's one
http://www.applianceblog.com/mainfo...-dryer-will-not-shut-off-after-dry-cycle.html
Wayne,
In truth, I was posting for an acquaintance per his late night "help me" phone call.
My info is third hand, but I will attempt to find additional info.
Thanks.
(apparently replacing the heat bank enabled him to "dry" again and the resistor, if it is bad has not made s noticeable difference. In trouble shooting, he just noted it showed "open")
Wayne,
Thanks.
I get those calls all the time.:happyyes:
But like I said above if the resistor is bad, the timer will advance in manual timed mode or any low temperature modes, but in either auto modes it will just dry forever as the timer will not advance until it is moved past the cool down cycle (last 15 minutes of the auto setting)
I almost feel so guilty. More then one customer has called about their dryer/ timers not working. I usually ask the age of the dryer and implant the idea of new dryer in her mind. Which usually means a new washer along with it. All for 50 cent resistor. :ashamed1:
