meaning of abbrevaitions ques?
wireman1
does the site have a list of abbervations for such terms as the following mlo , mwbc , ccc and others .what is the meaning of the abbervations. thanks
Here is the link directly to the abbreviations. I noticed CCC is not in there- soon to be corrected-- It is current carrying conductor.
And no EMT.
Slightly more seriously, a lot of local jargon gets used here.
I have no problem with that considering the basis of the forum.
If I don't what something means I can, and do, ask.
Members here have been patient and polite in explaining things for me.
And I greatly appreciate that.
And no THHN.
EMT and THHN do not need to be in the list - they are trade names more so than an abbreviation and are more universally accepted, and have been for years. Abbreviations like EGC, GEC, MWBC, CCC are more specifically used in places like this forum.
BTW- if you seriously would like to add some more please send them to me with the answer key- I may not know. I think the emt was a joke....
Wasn't intended as a joke. It's an abbreviation I've seen here ad had it explained.
Electrical metallic tubing.
And, as it's descriptive, I wouldn't have thought would be a trade name.
Similarly with THHN.
"THHN Wire stands for Thermoplastic High Heat-resistant Nylon coated."
Again descriptive.
Again descriptive.
Those terms are in the NEC but I could add a few-- If I did THHN I would have to do all insulations and that gets a bit much. Maybe I could work on a link that does the wire insulation on it's own page. The trouble is figuring out what they all stand for. I will give it a shot.
I didn't mean to put you to a lot of trouble.
Being a foreigner, I regularly come across terms and abbreviations here that are unfamiliar to me.
As I said, I can ask.
I been on this forum for a couple of years and I still have to figure out some of the acronyms.
Trade names and slang are worse.
BX
Greenfield
Minis
Bug nuts
Colorado Jims
Heater
Carflex
1900 box
Madison clips/Battleships
Mulberry
and the list goes on.
If you get a chance check these out and let me know of anything else to add there.
The "T" stands for thermoplastic insulated cable.
A single "H" means the wire is heat resistant.
"HH" means that the wire is heat resistant and can withstand a higher temperature. This wire can withstand heat up to 194 degrees Fahrenheit.
A "W" means that the wire is approved for damp and wet locations. This wire is also suitable for dry locations.
The "X" means the cable is made of a synthetic polymer that is flame-retardant.
The "N" is for the nylon coating that covers the wire insulation.
Thhn- thermoplastic high heat resistant nylon
Thwn- thermoplastic heat and water resistant nylon
Thw- thermoplastic heat and water resistant
Thhw- thermoplastic high heat and water resistant
Tw- thermoplastic water resistant
UF- Underground feeder
Rhw- Rubber insulated heat and water resistant
Rhh- rubber insulated and high heat resistant
Mtw- machine tool wiring
USE- underground service entrance cable
SE- service entrance
SEU- Service entrance unarmored I have also heard it as -- uninsulated (neutral)
SER- service entrance round
Xhhw- Cross-Linked Polymer High Heat Water Resistant
No big deal-- anything for you foreigners..:thumbsup: But we will have to differ on the way we say schedule and aluminum. :lol:
