And no EMT.Here is the link directly to the abbreviations. I noticed CCC is not in there- soon to be corrected-- It is current carrying conductor.
And no THHN.
I would add MCA-minimum circuit ampacity which is something we use quite often here on the form.![]()
Good one thanks...:thumbsup::thumbsup:Here is the link directly to the abbreviations. I noticed CCC is not in there- soon to be corrected-- It is current carrying conductor.
Wasn't intended as a joke. It's an abbreviation I've seen here ad had it explained.BTW- if you seriously would like to add some more please send them to me with the answer key- I may not know. I think the emt was a joke....
Electrical metallic tubing.
And, as it's descriptive, I wouldn't have thought would be a trade name.
Similarly with THHN.
"THHN Wire stands for Thermoplastic High Heat-resistant Nylon coated."
Again descriptive.
I didn't mean to put you to a lot of trouble.Those terms are in the NEC but I could add a few-- If I did THHN I would have to do all insulations and that gets a bit much. Maybe I could work on a link that does the wire insulation on it's own page. The trouble is figuring out what they all stand for. I will give it a shot.
Being a foreigner, I regularly come across terms and abbreviations here that are unfamiliar to me.
As I said, I can ask.
