ronbarbrey
New member
 - Fayetteville, NC, USA
I have an armory, (metal outbuilding to store weapons) at an army base. To supply the electical, I used a breaker in the main panel. This building's service is considered a sub panel and to seperate the ground and neutral at the panel and to use the main service grounding. This building also has a lightning protection system on the roof. My question is where to bond the LPS. Also, there are two grounding plates on each corner. Is it required to groung the LPS at the building or tie into the main building grounding system.
Thanks
			Thanks
