Gents,
To start, Section 700.16 uses the term lighting element, by defination, is that referring to the lamp element or in this case meant as a componet of the light fixture. Because the next sentence states ' such as the burning out of a lamp'.
This leads into my second question. If I have fluroescent fixtures outside an egress door, does this section mean that an emergency light source need two lamps or is two lamps and two ballast requred?
If it only means 2 lamps are required, can I assume that using a LED fixture with multiple LED lamps and one driver would be acceptable as a means of egress emergency fixture?
If I were to use a battery pack inside the door with a remote head outside. Do I need two remote heads or will I need a second battery pack with a second head outside?
Summary: Does this section refer to 2 lamps required or 2 lamps and power source (ballast, battery, driver)
Thank you for your help.
