Have a run of 3 inch from a meter pedestal to house and panel on 1 floor. The service enters through LB in crawl space.
Water leaking through LB fitting when it rains and the property is sloped so I am sure the 3 in has separated. The area only has 2 1/2 feet of soil than bedrock. So I am sure water running down the rock into the 3 in and since the water is entering above the LB it is draining in the basement.
Other than dig it up and reglue, find the entry point with a camera or etc... What the options? I could separate 30 ft out from building the PVC so water would not build and the would be the new low exit point? I could drill a hole below LB.
Thoughts. Thanks
Thoughts. Thanks
