ArchieMedes
Hi to all,
I am currently measuring the harmonics on a panel (just voltage harmonics) and is using fluke 434 as the measuring tool. I measured from the output of a thyristor a harmonics of above 15% but varying. I wonder if this is correct. I would like to ask how to correctly set the settings parameters on the fluke 434 to give an accurate harmonics reading.
I had already set the type of connection which is 3ph delta IT but there are still some other parameters in the setup func. preference in the setup menu which may be giving incorrect reading like offset,span,etc.
