Read the ques. over. It is ALL.. Goegle has nothing to do with a state Exm.
Read the ques. over. It is ALL.. Goegle has nothing to do with a state Exm. This chart doesn't show Copper or All.. So now what?
There is a code Ref. to busway's ( or the Questions states busbare). Now it would be nice if someone that read's this understand's
the different's.
Read the ques. over. It is ALL.?. Goegle?has nothing to do with a state Exm. This chart doesn't show Copper or All.. So now what? So now you put your butt in gear and check the site above the chart.
There is a code Ref. to busway's ( or the Questions states busbare?). Now it would be nice if someone that read's this understand's Maybe you should use spell check and make some effort on your own.
the different's.
Wow. If you think you have questions now, wait till you pass and start doing jobs on your own. You will find out how much you don't know rather quickly. Where will you get the answers then? You submitted a simple question without any detail, and received a simple answer. If you want a detailed answer, submit a detailed question, politely...
By the way, 1381
the answer from key test is 1050 amp's
By the way, 1381
I'm sorry, but what does 1980 VA have to do with the ampacity of aluminum bus bar?So all of this stuff we just went through, and nowone has the formla, for a state exam test Ques. that asked!
What is the ampacity of a 6-inch by 1/4-inch aluminum bus bar?
Somone has to have the answer!
The answer key is! 1980 VA Reference: 220.14
This is a Minnesota state exam!
