mivey
Do rabbit ears make a good ground?I think we need to know if this was a positive ground or negative ground rabbit.
Did the original experimenter give any details as to why polarity mattered?
I think the first rabbit died because he was the weaker of the two. Continuous shock was bound to kill the second rabbit sooner or later, polarity change or not.IMO the first rabbit died due to magnitude of the applied D.C voltage and the second rabbit died, despite withstanding the current from the DC source,due to change in polarity i.e due to a change in DC voltage wave form.
Where does it discuss the DC polarity?A clue to this phenomenon is provided in the paper...
Then how is it providing a clue to what the other scientist was doing? Can you please explain what you are talking about?It did not explicitly state it because,perhaps the two scientists did not know about the work of each other.
Then how is it providing a clue ......?
..... for electric stimulation (shocks) the waveform of the current can have a profound influence on current efficacy (Bikson et al. 2004).
OK. Meaning the changing polarity we have with the AC voltage wave is more dangerous that the steady voltage we get from typical DC.That is the clue.Do you see?
It can.
Think about an automobile ignition coil.
I don't have any evidence about 500HZ, but I have a statistical sample of one that says in the 1700Mhz to 2400Mhz range it is definitely a burning feeling. Hurt for more than a year as I recall....Once you get above 500hz you tend to feel more of a burning sensation then a shock.
Nope, AC is more dangerous. AC causes ventricular fibrilation which is by far the most common cause of death following a shock, DC does not cause fibrilation it just stops the heart which is much more recoverable than being in fibrilation. In fact DC is used to treat a person in fib.
It can.
ice
I would think that would still be considered AC because of the flywheel effect of the coil fed from points or electronically
Next week he will learn it can kill him also.I asked a new helper the other day what was the most important thing that he new about electricity. He replied "It will kill you. " I told him he gets an "A" for the week!!
PS: learn from teaching, not experience as that would be a bad thing.
That last part sounds like a corollary of the old saying I heard on day one of my apprenticeship: ...
