ggappa
- Nicollet, MN
what is the best way to de-rate nm cable? and the best way to find the proper values?
2011 code. thank you
the only reason i ask is because there are similar questions on a exam that i am taking. the reason its ran through a pvc pipe is because they are just using it as a short chase (nipple) into a panel. and the question asks how to size the pipe if nm is going through it.
I hope they don't expect you to know that info off the top of your head.i know how to do pipe fill im trying to find out how to do it for nm i see what you mean about what percent to use but how do you know what value to use (approximate area in.2) for a 12/2 or a 10/3 or any nm? this is a question on the minnesota journeymans exam.
Yes but not the dimensions of the cable.The formula or the area for every cable? The formula should be expected to be known IMO.
