B4T
- Long Island, N.Y.
You can get a very basic yet serviceable rotary laser for less than a c-note these days.
This is what I am looking for tomorrow in HD.. :thumbsup:
i dont think you should lazer level because someone cant put floor level. unless paid for time
Actually a properly set up laser would make the installation of the boxes faster and take less time.
Even if the floor is not level the cabinets will be installed level. So it is even more important to use a laser level, find the high spot and base the measurement from that high spot.
You also will not have as much trouble if you run into each other again on other projects.
That is if an experienced cabinet installer is involved. Some DIY just set them on floor and wonder why things don't fit right.
On the other hand in an old bulding that is all out of whack I might choose to follow the building and not a level.
On the other hand in an old bulding that is all out of whack I might choose to follow the building and not a level. For example horizontal wiremold or pipe on an old brick wall, I will follow the joint and ignore the level.
Not my problem to worry about others hack work, if my stuff goes in first it will be level.
So if your electric boxes are in first and not level why can't the tile guy follow what is already there?:lol:
