Speedskater
- Cleveland, Ohio
- retired broadcast, audio and industrial R&D engineering
On ground loops:
In systems with unbalanced interconnect cables (Audio, Video, Instrumentation or Control) ground loops are a fact of life. AC power leakage currents will use all possible paths to return to their source. So the best plan is to reduce the resistance (or impedance) of all these paths so that the leakage current voltage drop is reduced.
Reduce the length of the Safety Ground (EGC) wires from unit to unit. This is why those power conditioners that the hi-fi people like are sometimes effective, they connect all the Safety Ground plugs together.
Chose unbalanced interconnects with a heavy braided shield/return. For longer runs a shield equivalent to 14AWG is good.
When all else fails try this:
