I apologize in advance, No place to post a non electrical item, but this interesting enough.
Please click here
Thanks:Ronald
			Please click here
Thanks:Ronald
Please click here
Thanks:Ronald![]()
I must have missed something. What was so hard about moving the triangles?
It only works with Ie explorer, sorry
The question here is where did the extra block come from.
There is a very simple answer, I could say two words and you would figure it out easily![]()
Close but no cigar.
There are 65 blocks or parts of blocks either way its worked.
5 high and 13 long.![]()
Well i counted them again and it still comes out to 40 and 39...
Maybe i am getting the wrong one when i click the link.:blink:
The light green leaves gaps as well. Start by trying to line up the pieces in the original configuration.The two triangles sorta look like they have the same area from a distance but they do not. Check the slope on the green vs. the red.
Align the dark green on top of the red with the left corners and bottom ligned up. You can clearly see the difference. Something somewhere isn't lining up.Mivey
There is a answer on the Internet floating around similiar to what you are thinking. I started with that idea but it has nothing to do with that.
Its really simple I could say one word which is an object and it would be pretty easy to figure it out.![]()
Well the alignment sure is being altered and the figures do not line up. Bit and pieces are either hanging over or creating gaps. Evidently enough to make up for about one square.Remember when you rearrange them there is nothing being altered with the sections, other than there location.![]()
If the parts are not aligned the same, the footprint for the area is not going to be the same.
I agree. Line the pieces up like I described in #12 with the page zoomed in to 400% and it sticks out like a sore thumb. The little bits and pieces that hang over are not as noticible when looking at the whole thing together but obviously add up to about one square.There is sometthing about the angle of the solution that seems to be ever so slightly different just enough to reduce the area of the triangle by one square.
