petersonra
- Northern illinois
- Semi-retired engineer
188 pages?
			Yes - so? I thought we were discussing conventional 120/240V systems.120307-1120 EST
If leg A to neutral and leg B to neutral were "in-phase" and of equal magnitude, then you could put the shorting bar between them. That is what you do when you parallel generators. But if they are not "in-phase" then there will be a large current, and obviously you would not short those terminals together.
If he hasn't already; he will tell you that wt+180 isn't equal to wt+0. He just doesn't understand indiscriminate swapping in and out of the Sine argument is invalid.Vbn=-Vnb
sin(wt+180)=-sin(wt+0): no dropped phis
So do you mean that -sin(wt+0) is not equal to -sin (wt)?
Or do you mean that -sin(wt+0) is not equal to sin(wt-180)?
Vbn=-Vnb
Yes you can. I apologize for that. So you will stop speaking for me too - right?I can answer for myself Bob!
Mythical isn't exactly the right word here. By definition (1) there is one and only one phase. By definition (2) there are six phases present Van, Vna, Vbn, Vnb, Vab, Vba.Nonsense. There are TWO phases present, nothing mythical about it. We have long agreed though that the TWO phases are obtained by center tapping the transformer--the split phase system--and this system is known as a single phase system.
It's not tricky trig. It's using definition (1) instead of definition (2). Physically there's nothing split about the 120/240V system. Its a 240V center tapped voltage divider. Electrically (in consistence with definition 1) there is a single phase that runs from A to B. As such there is directionality to measurements. As such when you reverse your leads you have to invert the measured polarity of the voltage.All voltages in the split phase system do not carry the same phase. In other words, the phase of
sin(wt + phi) is NOT wt except for the trivial case!
And, we CANNOT dump phi with tricky trig!
Yes - so? I thought we already dismissed "in phase" and phase as being synonymous long ago. They are no more the same as phase and phasor - even if they sound alike.120307-12259 EST
Yes the discussion is about 120/240 systems. That does not mean in a discussion you exclude a description that will show the failure a given theory. My shorting bar shows that the leg A and leg B voltages to neutral are not "in-phase".
120307-12259 EST
No. I said it was difficult to read when providing a response because of all the tags/Hopefully to you - you said you couldn't read the original.
Sorry chum.Only if you include line-to-line voltages; not if you only consider line-to-neutral voltages - then there are only three phases.
Otherwise, you're imposing a definition that hasn't been generally accepted by both sides. If others have, they can deal with it; I haven't. If you want to say that is your definition, that is actually fine; but it doesn't obligate anyone else to accept it. This is why definitions need to be agreed upon early in such a discussion.
So:No. I said it was difficult to read when providing a response because of all the tags/
Sorry chum.
Six phases, all line to neutral.
- Vmsin(ωt)
- Vmsin(ωt+π/3)
- Vmsin(ωt+2π/3)
- Vmsin(ωt+π)
- Vmsin(ωt+4π/3)
- Vmsin(ωt+5π/3)
No.So:
Vmsin(ωt+π) = - Vmsin(ωt) and
Vmsin(ωt+4π/3) = -Vmsin(ωt+π/3) and
Vmsin(ωt+5π/3) = -Vmsin(ωt+2π/3)
is false?
And I can give you six voltages for a 3-phase wye system. Does that make it hexaphase also?No.
So what?
I gave you six different voltages.
I can express any one of them in terms of any other.
That doesn't alter the simple fact that there are six of them.
Yes - so, I showed you that all six can be written in terms of three identical phases - your "hexiphase" system is just a glorified three-phase system. Or are you claiming that every time you can find a different way of expressing a voltage function - a new phase appears?No.
So what?
I should have said "three identical pairs of phases" - but you knew what I meant didn't you? Unless you are mining for objections, of course.Yes - so, I showed you that all six can be written in terms of three identical phases - your "hexiphase" system is just a glorified three-phase system. Or are you claiming that every time you can find a different way of expressing a voltage function - a new phase appears?
Six different expressions...........I should have said "three identical pairs of phases" - but you knew what I meant didn't you? Unless you are mining for objections, of course.
