Why electrical charge on High voltage lines?
T
T.M.Haja Sahib
Guest
It is well known that the residual charge on live high voltage transmission line is neutralized before working hot on them.But a live low voltage line has no charge on it.It has only magnetic lines due to current flowing in it but no electric lines emanating from it i.e it is 'neutral'.Any explanation for this please?
Then I'm not sure if you are being clear about what you mean because there is both an electric field and magnetic field.
Do you have an article or something you could reference so I can have a little more background info on what you are talking about?
I can not readily produce the reference for the time being..But let us discuss in the mean time if you are willing.Do you have at hand any meter for measuring electric field in the field?
Both low voltage and high voltage produces both an electric field and magnetic field, but low voltage systems tend to be short runs with low impedance bonding that keeps static fields from building up.
One point even if the line is not energized it can build up a static charge, while many being installed are bonded to earth to prevent this, already installed lines that have been de-energized can have a lethal static charge, some switch gear can bond the line to Earth when power is removed.
with HV you have to neutralize (bond on) to bring your body to the same level of charge that is on the line, this is because at high voltage levels air is even conductive, and static build up can also be present.
also when transferring from a boom lift or helicopter to the lines you must bring these two separate metal structures to the same potential, also the rotors of a helicopter generate static fields that must be neutralized,.
Once on the lines your metalized suit will keep you from feeling the current in the air as a Faraday cage.
there are many videos of workers bonding on to work on HV lines to do line maintenance, search U-Tube
With due respect,I want to suggest you to try with your meter to detect any electric field of live low voltage line wires in your home or if possible outside and report please if possible.
Grab something like this ...
... set it to AM, walk around your home and report back any findings.
It is picking up electromagnetic field and not electric field alone.An electromagnetic field is one which can not exist without electric and magnetic fields but an electric field can exist without magnetic field.
My reasoning is simple.Take any portion of a current conducting wire.Before any current in it,the total positive charges in it is equal to total negative charges in it and so it is neutral.When there is a current through that portion,the total number of electrons going into it is equal to the total number of electrons leaving it so that it is neutral again.The same argument can be extended to the whole of the conductor and so the entire conductor should be neutral with no net charge on it.
