Don't forget, your entire country is geographically smaller than most of our states.
Yet, much less insular......
Actually, the system used in UK is that pretty adopted over all of Europe which somewhat negates the geographical argument.
As it happens we, our company that is, have designed, manufactured, and commissioned drives in many countries.
In doing so I personally have been to some far flung places like Hong Kong, the Malaysian jungle, the Sahara, etc.
A bit of an aside but still VSD related.....mods be kind...
The Hong Kong visit was quite interesting. The drives were located
under the walkways at the harbour front. Access was by lifting a manhole cover then climbing down a vertical ladder. Not for the claustrophobic....and a bit of a pain if you wanted to carry test gear and documents down in to the bowels of the sea front. The VSDs were driving pumps that circulated sea water to the cooling systems of the high rise, mainly commercial, buildings. That meant that we couldn't do any testing during office hours. So it was down the hole after 8:00pm. The problem was that the VSDs had an inordinate number of failures of the input rectifier and I was asked by the main contractor, the pump manufacturer in this case, to take a look. The fix was relatively simple. The politics was far from so. Mainstream Japanese manufacturer. Potential loss of face if someone independent is brought in to expedite a fix. Wading through syrup comes to mind.
Back on topic...
Yes, I take your point about ungrounded and corner grounded delta systems. Not something I've come across.
