K8MHZ
 - Electrician
What is the max amperage for a half inch (emt) conduit? You can get 3 # 12's so is the answer 20?
thank you
Where do you get 3? Table C.1 shows that 9 #12 THHN conductors are allowed in 1/2 inch EMT.
thank you
table 430.72(B)
thank you
Huh?????? ?
What does length have to do with this or the price of peanut butter?....length was not given, what % fill are you basing your reply on?
What does length have to do with this or the price of peanut butter?The fill is based on 31% that has been discussed already. See the notes to tables in chapter 9 and Annex C for more.
Roger
the origonal question was looking for the max. amperage for 1/2" conduit. Is the OP asking for wire size or OCPD?
Roger
Huh?????? ?
I would not use annex C as it is full of inaccuracies. I am not even sure why it is there as it is not an NFPA document.Table c-1 second colomn down with rhh, rhw, rhw-2. I'm way off .
Thanx
You are on the right track. Two conductors take up more space per conductor than any other number in a round pipe.
space
[speys] Show IPA noun, verb, spaced, spac?ing, adjective
noun
1.
the unlimited or incalculably great three-dimensional realm or expanse in which all material objects are located and all events occur.
2.
the portion or extent of this in a given instance; extent or room in three dimensions: the space occupied by a body.
3.
extent or area in two dimensions; a particular extent of surface: to fill out blank spaces in a document.
4.
Fine Arts .
a.
the designed and structured surface of a picture: In Mondrian's later work he organized space in highly complex rhythms.
b.
the illusion of depth on a two-dimensional surface.
5.
outer space.
I am an NPIT* and I was taught details are important so I will point out that three conductors take up more 'space' than two conductors assuming all conductors are the same size.
Now before you go one about how three bundle better than two, I agree, but even when bundled nicely the total space used is greater ......... details ...... details ........
(*Nit Picker In Training :angel:)
Your fill is off. Look at the one small circle in large circle. You can fit about six more smaller circles around the existing one. The one circle is far from 53% of the larger. At 53%, the smaller circle should have a diameter 73% of the larger. What you have for diameter is more likely the radius.Here is how fill works out
Glad you cleared that up! I was thinking "Natural Pain in the ^**!![]()
