First I guessed and
took 120/240 Ex., which I knew was 208. Did my math 208/240=.86666. Or 87 percent.
I did draw it out. Placed thing's where I felt they should be. If I had a amount of Res. that is on
each Res., that would make easer. I don't why I don't get.
I did not have algbra in high school, the way you do it is different to me. But I will try to figure it
out.
I would highly suggest trying a course if there is a local community college. I took night classes for 6 years, it was a PITA, but worth it.
You don't even need any "advanced" algebra.
It was only a polite suggestion, I found night courses very valuable.
As far as your diagram, I may look at it later, but I already passed my exams.![]()
I wouldn't expect it to take you more than a minute or so to find the solution to the problem, that is if you are kind of slow with mathematics. If you are below a math wizard but yet still pretty fair - you can solve this problem in less than 15-20 seconds after looking at that diagram I would think.
I could re draw the same thing but instead of using volts change the unit of measurement to inches and then make the resistors to proper scale according to length instead of voltage dropped - I don't know if I could make the solution much more obvious than drawing it that way.
It was 11:00PM, I was tired. But as you wish:
VR1=40V
VR2= 100V
VR1=VR3
Series circuit
R2 is 2.5 times the resistance of R1 or R2.
Ps. I never suggested an "advanced" algebra course.
Those are not my answers - at least one of has to be wrong - I suppose it could be both of us. Was kind of hoping OP would give it one more try before anyone answers.
Nice job on the Dia.. You know how to work the PC. alot better than I do. That is somewhat how they had it on Asw.key also. Alot of people say that it is easy. It is a good thing that the Pastor sermon this
morning, was how somtimes we feel alone. Well I feel that way on this one. I did much better on
220.55. Sorry I don't see it.
I didn't have one. I have Doc. Appt., jury duty, and all these thing's hapening at once. Mom's
set for knee replace menet on Tues.. I have to much going on now. Still don't get it but, I have to deal with Mom.
Thank's
