hurk27
- Portage, Indiana NEC: 2008
I was called out to a small convince store to give a price on repairing the door lights for a product display cooler.
To my surprise I found that they have the above type fixtures in them and a lamp between each door and one on each end for a total of 8 lamps, the first 4 are glowing purple, the last 4 only has one lamp lit so maybe just lamps, but owner is saying that they are not lasting as he is changing them on a weekly bases.
First I have never seen a slimline type fixture used in a cold environment, most coolers around here would have F48T12HO type lamps.
I know the new F96T8 electronic fixtures are good down to 0 deg. F and have a very high output while using less energy, which would be a perfect retrofit if they made them in a 48" version, but for the life of me I can not find any 48"T8 single pin or electronic ballast for even a 48" T12 slimline/single pin.
Has anyone run across this problem? If so what was the answer?
Also all the magnetic ballast I find are 2 lamp, and I think these are 4 lamp???:?
4 foot slimline are popular around here in 2 lamp strip lights but that is about it.
These are built into the cooler and its about as old as the building (70's)ish
