uwireme
- Cottonwood, CA
I hooked up a swim spa per the manufacture cut sheet ?50 amp breaker and GFCI?. Inspector found a nameplate on the side of the unit ?Circuit ampacity 40 amps maximum?. I have a 60 amp breaker from a sub panel to a 50 amp GFCI breaker disconnect, can I move the 50 amp GFCI to the sub panel and change the spa disconnect breaker to a regular 40 amp?
