What is this?
sd4524
One wire goes under the house to a water pipe ground connection. I don't It says "aerial ground" on the face of the device. I think it may be for testing that a satelite or antenna is properly grounded?
My guess, it would be for grounding the chassis of a radio or TV. Tube radios and TVS had the chassis used as the common.
To clarify: One wire goes to the water pipe/ ground. The other wire was not hot/ energized. I tried to research it when i first found it but couldn't figure out exactly what it is.
It's a radio outlet for early tube AM radios; one lead to a longwire antenna, the other to ground.
Predates satellite by quite a few decades...
/mike
/mike
I concur. This would be like a cable TV outlet, but for radio. The weird part is that it looks identical to a NEMA 1-15 socket. I'm wondering if it's a different size? The uppermost prong in the first photo looks like it might be too narrow for a standard prong.
There weren't any specifications for radio sockets, so there are a few variations. Here are some other examples:
It is an Old tube type radio antennia outlet, one side would connect to a wire that ran through the attic and the other would go to the water ground, lightning strikes. Usually see them in houses built around the 1930's
