Fordean
- New Jersey
- Electrical Contractor
In a printing company.  They ordered presses @ 480 volts.   And they had a service installed years ago at  208.  Now we bumped up voltage with Trans.  When first energized.  Tripped GFI.  Now called D tech line.  And they stated GFI setting set at factory to zero.  I checked and was still at zero. They suggested moving gradually to it holds. Moved it in slight increments. Seemed fine. Now Im told it began to trip. When off hours and closed.  Utility. shutting down or Weather related off time.  When it comes back online. I Suspect magnetic coils are tripping it again.  Can I install a rectifier. If I'm using the correct terminology.  Any suggestions.  What is a normal GFI dial setting.  I        have to do the math I'm sure.  But wunder why it was on zero to begin with.
