Power Lines
wayne
Thanks for your clarification.
Don't you think on a moist wooden pole the shocking experience you described may be present and so bonding the wooden pole also makes sense?
wayne
By that logic, should we bond the trees also so that children or hunters won't get a shock when they climb them?:lol:
It is a different issue.:roll:
You do not seem to recognise the protection of trees against lightning,for example.
There is playgroung and baskeball goal equipement located under power lines. I'm getting electrical charges from the metal of the playground equipment. There also is an electrical power distrubtion station located acroos the street from the playground. is it possible to have stray voltage in the ground or the power lines my problem. Is there anyway make the equipment safe.
Thanks Ken
That should keep them from hanging on the rim :)
Seriously, just call the PoCo, they will investigate.
