Hello
I run a one man engineering shop in a small market. In order to keep busy I need to be quite diverse, so project portfolio includes small commercial buildings to water and waste systems to streetlighting to power distribution (including some high voltage).
Over the course of the past year I have been steadily gaining more traction on projects where power analysis tools are necessary. I have in the past subcontracted these elements as required but now I think it is time to add these capabilities to my core business. I believe my main use for the tools will be arc flash and fuse coordination studies but I expect to grow into the tools as I gain experience and more complicated projects come along.
I have narrowed down the field to SKM and ETAP and I have no doubt that either of these packages is more than adequate for my small business.
Before I pull the trigger I would really appreciate some input from users of these tools.
can you tell me......
1) Does anyone have any recent experience with the support and training offerings of each of these companies? Any red flags?
2) How helpful are these companies when it comes to questions regarding how best to apply the products in a practical way to a design problem?
3) Is SKM still going strong as a company? Are the incremental improvements compelling? As the ETAP sales guys tells it (of course!) SKM is fading away, cutting engineering back... Is there any evidence of this?
4) In each package is a node/bus equal to a node/bus? i.e. if my project eats 60 nodes in SKM will it be about the same in ETAP?
5) Are there any significant intangible benefits to either package that I should consider?
Here is my take on it.... I've tried SKM and while it seems a bit clumsy I know that a bunch of you are using it to do real work, so no doubt I can learn to do the same. ETAP is a fair bit more expensive and I imagine that I might like the experience of working with it better, but it needs to be a whole lot better for the extra dollars, and so far I have no evidence of this.
(I intend to sign up for training by the way.)
The SKM package I am considering as a starting point is a 50 bus license including Dapper, Captor, and ArcFlash. Given how I describe my business does this seem about right? For a few more bucks I can add IEC 909, IEC 363, TMS. I'm not sure if I need ArcCalc, it seems similar to ArcFlash...?
I expect some project may roll in that needs more than 50 buses but I think that will be a good problem, if you know what I mean.
thanks a bunch!
thanks a bunch!
