- Tennessee NEC:2017
- Semi-Retired Electrician
Does anyone know if the different mfg of remodel recessed lighting all require the same size hole to be cut for the lights? In other words, does Halo 4" need the same size as Juno, or 4" Litolier? I've only used the templates that come with the lights and have not measured them.
I have a new "Hole Pro" hole saw and would like to know if I can pretty much use the same setting, whether 4,5, or 6", for different mfg. I do know that some of the air tight housings could use a larger hole than their template. They don't tell you that in their spec sheet though.
