I have a two section panel with a parallel feed to the first section. Then a parallel feed to the second section. The panels have two 4" nipples to interconnect the two. Does the nipple do the bond or would a wire bond be needed? With two nipples would I need a bond to go thru both nipples since paralleled or one sized to the over current amperage? I am having a brain freeze on this for some reason. I want to say the nipples are the bond or one bond wire sized accordingly. What you say.
