Jsim4109
- Cherry Hill, NJ,USA
Does a GRC conduit riser, soley for the protection of a tray cable from an enclosure to the cable tray, which is fastened to the enclosure with standard locknuts need a bonding bushing attached to the cable tray?  The tray cable has an equipment grounding conductor which is attached to the enclosure ground bar and is the effective ground fault current path.
