What would happen theoretically if the utility had a pole mount single phase transformer connected 7200kV L-N on the primary and 120/240V secondary, and they bonded the primary neutral to the secondary neutral. The netural from the secondary is brought inside your panel and bonded to ground/earth.
Now what if the utility transformer primary ever lost its neutral, would the transofmer still function through the primary neutral bonded to the secondary and then to earth in the panel? If so and you for some reason lifted the secondary neutral or ground, could you be subjected to the entire 7200V on the primary of the transfomer since the lifted neutral/ground would presnet a higher impedance (voltage divider) than the primary windings?
