electric water coolers
Indoors not likely.
Location, Wet. Installations underground or in concrete slabs or masonry in direct contact with the earth; in locations subject to saturation with water or other liquids, such as vehicle washing areas; and in unprotected locations exposed to weather.
YESSSSS!!
But the question was "WET LOCATION"?
Is 6' within a sink a wet location?
Are you using bubble covers in a kitchen?
So IT'S NOT A WET LOCATION
Do you need GFCI in a garage?
Are you using bubble covers in that said garage?
So is the garage a wet location because you have to use GFCI's?
Doesn't matter you still must GFCI. 422.52 (2008)
YESSSSS!!
read sec 406.8 ('08 code)
Electric water coolers .....
wet location or not??
If an area is a wet location or not has nothing to do with a water cooler being there or not.
My basic rule of thumb for deciding if an indoor location is also a wet location is to look at the building materials used in that area.
If it is a wet location building codes will require more than drywall and carpet, you will see floor drains, tiled walls etc.
