Is there anything in 2011 NEC that specifies against the use of a regular plastic outlet box in an adobe wall that will be finished/patched with concrete or plaster?  The only thing I can find that comes close to that is 314.15 Damp or wet locations.  But, then, would this situation even fit that as the adobe is baked and the concrete/plaster will eventually dry.  Maybe there would be a little moisture in the box, though, as the adobe heats and cools.  ???  Thanks
