3/4" or 1" EMT ELBOW
Evidently it is. Does it need to be short radius before it can be called an elbow? I have heard them called "sweeps" or "sweep elbows"
In my locale, a 'sweep' is a factory bend. Usually a 90. If we are doing the bending, the bends are just referred to by their degrees. 'Elbow' is almost never used by electricians and when they do use it they usually mean a fitting, not a bent pipe.
If you ask a new apprentice to get you a sweep - he might come back with a broom:)
What I said was that if you see a job where they used nothing but straight pipe and pulling ells instead of bending elbows then you know the installer was good at using a hack saw and not a bender. Why would you think that I meant they were using pulling ells instead of elbows to go around an outside corner. :?
Whatever. We are somehow not hitting the same page at the same time. We will try some other time.
