sselman
- Houston, Texas
I am curious if it is acceptable to use a general purpose toggle switch rated for the intended load and voltage to be placed in a device housing rated for Class 1 Div.I installations or would I need to technically get agency approval on the assembly as a whole?
Basically I want to mount a GP switch inside the same device enclosure used for rated Class 1 Div.I controls (switch).
I would imagine the switch may need to be encapsulated or hermetically sealed in this application but finding a suitable 3PDT ON-OFF-ON 3 position switch is not easy and the one approved device we have been using has an inconsistent but always long lead time causing supply chain to plan and do work.
The switch is used to change directions on an XP rated AC motor.
Thanks
Thanks
