HVAC calc
Elect2011
Reston, VA
what is the KVA value that I need to used in a house calculation for the follwoing:
a/c 3 ton unit.
heat pump 3 ton with 8kw backup heat.
thanks,
hvac calc
hvac calc
if it is a single phase 208/240 volt unit an avg, of 7 amps per ton is usally very close for a cond. unit.
a/c 3 ton unit.
thanks,
depends on manufacturer it varies a lot
Stickboy is right ask again, just be sure to ask for min. circuit amperage and max HACR breaker
