transman2
- Brooklet,Ga.
I have a new underground service going to a transocket and then a 400 amp fused disconnect outside of building. Then I have 2 - 200amp MLO panels that I'm gonna feed with 2 parralel runs of 3/0 copper to each panel in PVC. What size grounding conductor should I use for this application? Also for the ground rod what size grounding electrode conductor should I use. Could you please refer these questions to code section. Thanks.
