I have a car trailer (for racing) that is wired up with a 6 circuit panel. The panel is wired with a 10-4 SJ Cord and has a 30 amp plug to run off of a generator ( 240 v) . I am using a Yamaha EF6300 ISDE generator. When plugged into the 240v outlet. I have 250/125 volts at
the panel. With just the air compressor running the compressor barley turns over and will trip the generator. If I use the pigtail I have
and plug the trailer into the 110v outlet on the generator I can run everything in the trailer including , The air compressor a roof air
conditioner, 8' lights and 2 spot lights outside. any help on why I cant use the 220v on generator would be great. ( the generator is New)
