maghazadeh
- Campbell CA
Is anybody here knows of a good and reliable Diesel generator-set other than Chinese made. I would rather have a USA made.
This is for a Commercial office building being build and no natural gas available and the owner does not want gas service.
I need one somewhere between 7 -to - 10 KW, 7KW minimum run with 17 kw start capacity.
It will be used to run (2) 1 HP storm drain pumps in case of utility power lost. we may beef up to (2) 1 1/2 HP pumps.
I can use either single phase 240/120V or 208/120V 3 phase.
I had no luck with Cummins or Peterson generators. the smallest they make is 13 KW.
The Lister Petter units are good units For what is worth we have received feed back that obtaining parts can be problem.
Please help and thank you in advance for your reply.
