102 Inspector
 - N/E Indiana
 - Inspector- All facets
A detached garage was sub-fed from the home with 4-wire assembly to a subpanel. Neutrals and grounds were isolated in the subpanel with the grounding bar kit bonded to the enclosure through the bonding screw. The homeowner installed 2- GFCi breakers to protect the general purpose receptacles and immediately the breakers trip with no load on them. A regular breaker was installed and no tripping. The homeowner wants the breaker instead of receptacles, but as the inspector, I have no clue what is wrong with this installation that is causing the tripping. Any thoughts?
