scottp628
- Pacific North West
looking for a bit of help. this is in a bedroom circuit, house about 25 years old. standard white NM wire(before colored wire and GFCI outlets). Adding a timer switch for the bath fan, I got hit by the bare ground wire. tested for voltage, 50 volts on the ground wire. separated the feed at the switch box. Voltage is correct from the panel, hot to ground, hot to neutral and  neutral to ground. On the feed out, ( there are three outlets remaining on this circuit in the bedroom). I unplugged everything from the outlets. broke the ground connection at the switch and got 50 volts on the ground wire. removed the three old back stabbed plugs checked for loose connection there were several, checked wires for nicks or cuts. the wire casing looks like they were stripped with a razor knife and replaced with new outlets. Voltage dropped to 24 volts on the ground. I went to each outlet and "broke" the ground connection and tested for voltage. with the ground connection disconnected between the outlets there is still over 24 volts to ground. I thought a screw may have hit the wire in the wall. yet the voltage difference is continuous . I have checked outside to see if an additional outlet was tapped off yet I have not seen an additional outlet. The service is overhead on the opposite side of the house. I would appreciate comments, both helpful and comedic.
