powerplay
- In front of a computer.
For a large service, it was unanimous that aluminum feeders would work fine and cost alot less. From the splitter to the two 200amp panel feeding an agricultural lighting load, would there be any issues from using aluminum?...should copper be used for the final short length to the panel? I have someone that seems convinced that the used core and coil ballasts are burning out because of some voltage drop from the last leg that is causing problems with a few lights.
