common sense would indicate that approved means and methods might provide
some insight here... the handbook does not specifically speak to aluminum conductors,
but one of the common means for feeding fire pumps is MI cable, which is ungodly expensive.
would you think that someone going to the trouble of making a COPPER JACKETED cable
would put aluminum wire inside it?
wikipedia has some information about MI cable..
http://en.wikipedia.org/wiki/Mineral-insulated_copper-clad_cable
my thought is that for a critical application, why on earth would you consider using aluminum
wire? the raceway must be either outside the building, or encased with 2" of concrete.
aluminum melts at relatively low temperatures compared to copper... 1220 degrees VS.1983 degrees.
from the NEC handbook:
"The difference between a 2-hour fire rating of an electrical circuit, such as a
conduit with wires, and a 2-hour fire- resistance rating of a structural member,
such as a wall, is that at the end of a 2-hour fire test on an electrical conduit
with wires, the circuit must function electrically (no short circuits, grounds, or
opens are permitted). The circuit and its insulation must be intact and electrically
functioning. A wall subjected to a 2-hour fire-resistance test must only prevent
a fire from passing through or past the wall, without regard to damage to the wall.
All fire ratings and fire-resistance ratings are based on the assumption that the
structural supports for the assembly are not impaired by the effects of the fire.
The UL 2004 Fire Resistance Directory, Volume 2, de- scribes three categories
of products that can be used in the fire protection of electrical circuits for fire
pumps: various electrical circuit protective systems (FHIT), electrical circuit
protective materials (FHIY), and fire-resistive cables (FHJR). (The four-letter
codes in parentheses are the UL product category guide designations.) For
information on electrical circuit protective systems, see UL Subject 1724, Fire
Tests for Electrical Circuit Protective Systems."
